Smog pump delete?
Old Nov 13, 2001 | 11:58 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Smog pump delete?
I want to take off my smog pump. Is they a part # from GM part direct for a dumbing pulley?
Mods: ZZ4 engine w/stock TPI, adj, fuel pres. reg., MSD 8.5, HI6S ign. w/ PS-91 coil, K&N filter, TPI air foil, Hooker comp. shorties, American Thunder flows. 160* stat., TB bypass, 3"cowl, bat. relocate, AC delete, stock T-5 w/ 3.42 rear, ported plenum, 24# inj.
Old Nov 13, 2001 | 12:36 PM
BitchinCamaro's Avatar
If you have a sepintine system you don't need a dummy pully, there is a tech artical on this site that give you a part number for a different belt and the new routing. If you really want to do a dummy pully thing, I have heard of people gutting their old one.
Old Nov 13, 2001 | 02:24 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
GM makes an idler pulley for the AIR pump. The part # is 10186167. The idler looks better than re-routing the belt IMHO.
89GTA-The Driver
92Z28-The Lawn Ornament
"Sunday Money"
Old Nov 13, 2001 | 08:37 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
how does the idler look better? are you talking about a serp setup
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 14, 2001 | 10:59 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I have a serpentine system. I just think it looks cleaner than having a bracket with no pulley in it. I also didn't want to screw around finding the right length belt for my u-drive pulleys. If you don't think the same that's fine with me
89GTA-The Driver
"Sunday Money"
Old Nov 14, 2001 | 10:45 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
How much was the idler pulley and what was the part #?
http://kiztope.50megs.com
92 Pontiac Firebird Formula WS6 5.7/A4
K&N, Blue Streak Cap and Rotor, strange unknown exhaust system (sounds good though)...
Mods are in direct proportion to income!
92 Rs 3.1/T-5
Beautiful car, many mods, but now I am turning attention to the 'bird!
AIM : Theonekiztope
ICQ: 8787542
"Maybe one day life will take a turn. When it does Lean into it!" Leon Calrinsky (98)
Old Nov 15, 2001 | 08:04 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
The part # is listed above. It should not be more than $35-$40. Try http://www.gmpartsdirect.com
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
