How hard is it to remove smog equipment?
Old Nov 15, 2001 | 01:37 PM
rondubbs's Avatar
is it simple unbolting?
if anyone has pics or links i would appreciate it? i know there is a tech article on this site,, any others?
and is there a noticeable increase in hp? any ses codes?
is there a huge increase in emissions?
my car passes NYC dyno emmissions easy with no cat, right now.
1988 GTA Trans Am 350tpi: 48k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass, homemade cold air induction, timing @ 10*, flux capacitor@ 1.21jW, driver side floor mat removed
1/4 mile - 14.58
Old Nov 15, 2001 | 02:35 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
It won't pass a visual inspection anymore. IF the car's been running (which it prolly will since you'd be waiting in line), You should have no problem passing emmisions.
There's no noticable HP increase, even in the 'butt-dyno'
I did it mostly to start clearin up the engine bay, save weight, and i don't want a new cat or headers w/ air fittings.
There'll be no codes thrown by its removal.
You'll need a new belt. (98.6" in our case I believe) I went to depot and bought 9 small pipe-plugs for the factory air fittings and cat, put on for peace of mind since I believe they're "one-way" anyways.
It took me and KZad 2 hours if I remember correctly. But then again, I am very very slow at car work
Just saw the fact that u have no cat now. In that case, if you passed emmisions without a cat, this should be cake.
That should help, do a search also
http://www.tcnj.edu/~esposit3
https://www.thirdgen.org/rides/index...ew&rideid=1137
Member of FBS
AOL IM Name: JimmyTime5
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
Old Nov 15, 2001 | 06:35 PM
rondubbs's Avatar
no lines to wait on for inspection in NY
thanks for the info
Vintageracer
Jan 10, 2020 05:33 PM
gixxer92
Sep 1, 2015 04:32 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
