Need help with Power Steering bracket configuration on 86 TA!
Old Nov 15, 2001 | 05:32 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I'm finishing up my engine install and trying to get the power steering pump put back on. Problem is... I can't figure out the configuration of the bracket. This car is a 1986 Trans Am... before the serpentine assembly. The AC and the power steering use the same bracket(s). There's like 3 pieces to this bracket. The AC has been delted but that isn't helping any. One problem I see is that one piece of the bracket attached to the old manifold and well, I've got headers on there now. Help ASAP would be greatly appreciated. Pics... anything. Thanks in advance.
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.7:1 Compression, Stock TPI ported, 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech hot coil.
Old Nov 15, 2001 | 08:11 PM
Ok, nevermind... I figured out a way to "rig" it up. I now have a hybrid power steering bracket... half power steering bracket, half smog pump bracket. Hey it works.
Old Nov 16, 2001 | 12:35 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
there is a guy in e-bay sellin bracket for just this problem.... check it out only like 24 bucks
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
