What's a good place to start with the fuel pressure!
Old Nov 15, 2001 | 08:15 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Ok, here's what I got.... 355, 24# LT1 Fuel Injectors, Adjustable Fuel Pressure regulator, and I'm using the stock 305 computer chip (temp situation). What would be a good fuel pressure to start with using this computer/injector combination?? Thanks in advance.
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.7:1 Compression, Stock TPI ported, 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech hot coil.
Old Nov 15, 2001 | 09:55 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by 86TpiTransAm:
</font>
i would say 35 - 40 psi. the stock 21# were rated at 40-47 psi
Old Nov 15, 2001 | 10:20 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
well, you're grossly overrich running a MAF car w/ a 19 lb injector chip w/ 24 lb injectors. Unless you have a holley regulator you can't get the FP low enough to make up for it.
My recomendation, as low as possible until you get a properly set-up chip in it.
Old Nov 16, 2001 | 02:23 AM
<font face="Verdana, Arial" size="2">Originally posted by Ed Maher:
</font>
Funny you say that.... I have a Holley Fuel Pressure Regulator. The lowest it goes is 30psi. So you think I should go there huh?? I'll have to give that a shot.
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
R3500
Aug 17, 2015 12:16 PM
Kaweh
Aug 9, 2015 02:54 PM
killer777
Aug 8, 2015 02:47 PM
