trans am/gta ram air system for free!
Old Nov 16, 2001 | 12:52 PM
pontiac's Avatar
here's step by step instructions:
- remove the fog lights
- move the smog canister to garage shelf. do not disconnect hoses and wires.
- open the air cleaner assembly
- rotate base 90 degrees clockwise
- close air filter assembly
air from fog holes is directed to fender. on the fender there's a big hole just around air filter assembly, so the intake is pointing the cold air from the fender! that's it
-P (free hp(1) since 2001)
Pontiac Trans Am GTA'89
CC1 GW6 G80 JG1 L98 MXO N64 WS6 822
mods: firebird '89 four spoke steering wheel and i'm still not running low 13's yet!
Old Nov 16, 2001 | 04:05 PM
breathment's Avatar
<font face="Verdana, Arial" size="2">Originally posted by pontiac:
</font>
hmm, not worth the 1 HP
however, i still think u would get cooler air leaving it there, thats how the SLP set up works. alot of air still gets in there.
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 16, 2001 | 04:51 PM
Drakar's Avatar
Or do it the poor way and cut big holes in the air box ...... more air instead of through that stupid silence ring/tube.
1989 Trans Am GTA
Old Nov 17, 2001 | 10:00 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
And you can leave the carb canister in place to keep your gas tank from imploding.
-- Joe
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
The_Phoenix
Feb 4, 2016 07:10 AM
bryan623
Aug 10, 2015 11:33 AM
