TPI Problem - 1989 Formula 350
Old May 31, 2008 | 04:01 PM
C-McN's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L V8 TPI
Axle/Gears: 9-Bolt, 3.27
Car: 1989 Firebird Formula 350.
Problem: Car starts and will sit and idle with no problems. Car can be driven LIGHTLY without any hiccups, i.e., keeping your foot out of it.
Open the throttle, however, and Houston we have a problem. Car seems to load up and flood itself, begins to idle/drive poorly. If you shut if off, you're rewarded with a Service Engine light and not being able to start it again for a while.
Recently replaced the plugs, wires, cap and rotor and all the filters. Tested the coil and the ignition module, both are fine. No codes in the computer. Fuel pressure at 43 psi. at start-up, and will drop SLOWLY, likely a leaky injector.
What causes this? The ECM is the most common culprit, apparently. Can somebody explain the possible malfunction and how to fix it?
Old Jun 1, 2008 | 09:52 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: TPI Problem - 1989 Formula 350
Start by pulling codes from the ECM...it'll give an idea what to look at.
ECM is most likely the LAST cause of the problem.
Old Jun 3, 2008 | 11:17 PM
the blur's Avatar
you said it yourself, bad injector.
Old Jun 5, 2008 | 01:30 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
dose your fuel press drop while it is running? if so, how low dose it go? if it gos below 40lbs that would be a problem.
also look into the CTS coolant temp sensor, that would not let it start after it was hot, and would start again untill after it cooled down, and didn't set any codes when it happened to mine.
Old Jun 7, 2008 | 05:19 AM
Nater36's Avatar
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
fuel injectors.... just went through the same problem and dumped loads of money into mechanic guesses and finally went with mine and that was it... its crazy how it acts w/ just 1 bad injector
okfoz
Mar 9, 2017 02:35 PM
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
Sanjay
Aug 12, 2015 03:41 PM
