TPI runner gaskets
Old May 31, 2008 | 11:14 PM
the blur's Avatar
TPI runner gaskets
you guys installing them dry ??
or with a gasket adhesive ??
permatex???
Old May 31, 2008 | 11:27 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: TPI runner gaskets
always done mine dry
Old May 31, 2008 | 11:35 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
I also installed mine dry it is only sealing air. I did spray the back side the top set of gaskets on the runners with spray adhesive. I never had much luck with the plastic clips that are designed to hold the gaskets on.
Hawkeye1980
Aug 31, 2015 07:09 AM
mdtoren
Aug 23, 2015 12:52 PM
qz6lwp
Aug 20, 2015 08:10 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
