fuel pressure ???
Old Nov 14, 2001 | 05:33 PM
gta007's Avatar
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
fuel pressure ???
ok i put a adjustable fuel pressure reg. on my 5.7 tpi. last week and set the psi at 50psi car runs great.but when i turn it off it wont start back until i releve the fuel pressure. i can set the psi back to stock setting.it restarts fine any help would be great. thanks
89 gta 5.7 to many mods to list 89 formula 5.0 tbi (commuter)
Old Nov 14, 2001 | 06:48 PM
Desert86Roc's Avatar
Sound like you set the fuel pressure with the vacuum line connected. Disconnect the vacuum line, plug it, and THEN set your fuel pressure to 50. Then at idle, your fuel pressure with the line connected will be much lower.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] www.MetzlerRacing.com
Best ET @ 1250 ft[*] 15.352 @ 91.215 mph (uncorrected)
Old Nov 14, 2001 | 08:39 PM
gta007's Avatar
the line was dis connected,when i set the pressure.
89 gta 5.7 to many mods to list 89 formula 5.0 tbi (commuter)2000 buell X1 1203cc
Old Nov 17, 2001 | 12:02 AM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
what was the outcome gta007 did you back off on the fuel pressure? did you feel a diff in performance when you installed the reg.
[This message has been edited by SLP-GTA (edited November 16, 2001).]
Old Nov 17, 2001 | 07:19 PM
PALM BEACH IROC-ER's Avatar
<font face="Verdana, Arial" size="2">Originally posted by gta007:
</font>
You nedd to use a fully adjustable rising rate fuel pressure regulator, it allows you to keep stock fuel pressure at all but wot. You can adjust this regulator up to twice the stock pressure and at increased ratios, "but caution is urged here, perfect fuel lines, injectors and seals are a must to prevent or reduce the risk of fire!" A RRFPR is your fix and the extra power that can be had is worth every cent, and then some!
See it at www.cartech.net/
Old Nov 19, 2001 | 06:47 PM
BlazinOR's Avatar
These adjustable fuel pressure regulators, do they replace the factory one? SOrry for my apparent ignorance, its just that I'm.....well, ignorant!!! Learning, learning all the time.
'79K5 Blazer with 406TPI
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
