What Is An EGR Relay? where can i get one?
Old Nov 21, 2001 | 07:39 AM
f41camaro84's Avatar
i putting tuned port on my camaro and my all data says i need an egr relay. it goes on the intake, near the distributer. and it connects to the egr and the sensor under the plenum. do i really need it? where can i get one?
Old Nov 21, 2001 | 08:00 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
If you're talking about the EGR solenoid (no relay for the EGR), then yes you need one. This solenoid activates the EGR valve when the computer tells it to. You can get one from the dealer, although some parts stores may have one too (probably cheaper). Mine's in the attic with the EGR valve since I disabled it in the chip (off-road use only ) and blocked off the EGR port on the intake manifold.
Greg Westphal
'87 IROC 355TPI/A4
Old Nov 21, 2001 | 08:03 AM
greg, will you sell me yours? i'm need one. and if possible any wiring going to it?
thunder57
Nov 7, 2015 02:28 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
