MSD Upgrade is this right???
Old Nov 22, 2001 | 03:03 PM
Drakar's Avatar
Im upgrading every part of my ignition from plugs to ign and I have collect the part #'s I think are right for my car, I just need a second or third etc etc opinion on whether these are correct or not, I pulled them all from Summit so Im pretty sure there right.
MSD-31189 8.5mm universal wire setup V8 - should I get custom for this instead??
MSD-6200 6A ignition
MSD-8223 Blaster 3 coil - no diff between 2 and 3 right???
MSD-8410 Rotor - just need this replaced
MSD-8426 Cap - just need replaced
and I was think a bosch platinum, most people say +4 is a waste so what about the (+2)?? or the regular, any good, I want something very good but not race read (don't need that yet)
Any help on this will be great.
1989 Trans Am GTA, Gutted air box, K&N, Koni Sports
Old Nov 22, 2001 | 03:21 PM
89tpi's Avatar
For plugs the AC's are just fine. As for the wires i have the MSD 8.5 the universal fit and it worked good but if you are willing i would cut them yourself but the universal will work fine. I have the blaster 2 and love it to death. And for rotor and cap sson i will be getting those from MSD but everything you mention sounds perfect.
89 Formula WS6 w/ TPI 350
MSD blaster coil and 8.5 mm MSD's
K&N filter
Old Nov 22, 2001 | 04:12 PM
nblanchard's Avatar
I have pretty much what you mentioned... although I am not sure on the part numbers... I may be able to fish them up. If you get the custom fit wires for your car, one of the wires WILL be short. Unless they gave me the wrong set. But I double checked, and they said it was the right part number. The wires I got were for a BB Chevy. :/ Anywho... it all works good though. Looks nice too... it'll look better when I get my polished plenum and runners on there, as well as my blueprinted and flow matched injectors which I am getting painted red to match the MSD parts.
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Best ET 14.559 @ 95.25MPH
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Old Nov 22, 2001 | 10:12 PM
Drakar's Avatar
So if you got the BB and one was too short would that mean the SB would be really short or ????
Is there a kit that you can put your own together????
Like a build your own or is that what I have listed???
Old Nov 22, 2001 | 10:45 PM
89tpi's Avatar
i siad i had the SB kit and it works but there is one wire that was a little hard for me to get on i think it is 6 or 8 but its all a matter of finding how to route it.
K&N filter
Old Nov 23, 2001 | 03:01 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've got the same box and coil on my car.
My friend has a 90 Formula 350 with the SLP T-Ram and same box and coil, works great for him, my doesn't run yet, so I can't tell you if it does anything better than stock.
This is where I mounted my box, I need to move it now......
....since I installed this cool SLP Dual Cold Air Intake.
WS6 Trans Am.
View My Ride @ thirdgen.org
[This message has been edited by Zepher (edited November 23, 2001).]
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
