My new(temporary) cold air induction
Old Nov 22, 2001 | 08:19 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I say it's temp because the flexable duct will be replaced with mandral bent aircraft aluminum tubes(dual).
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
[This message has been edited by John Millican (edited November 22, 2001).]
Old Nov 22, 2001 | 08:24 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey man,
Not bad. Where did you get that y-peice for the middle?
Anyway, you should really try to make a heat shield so it sucks in air from the fenders, rather than the engine compartment.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
Old Nov 22, 2001 | 08:36 PM
poncho9789's Avatar
Sweet, I would also like to know about the split pype. It looks real good in front of that lt1 intake.
Old Nov 22, 2001 | 08:49 PM
Engine: 4.0L
I made it.
3" PVC long elbows cut and welded(epoxy) together and sanded smooth/painted.
Old Nov 22, 2001 | 10:06 PM
irocbsa's Avatar
Nice!
Old Nov 22, 2001 | 10:23 PM
breathment's Avatar
hey i like that alot, too bad our engine compartments are too cluttered though... grrr
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 23, 2001 | 03:06 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
<font face="Verdana, Arial" size="2">Originally posted by breathment:
</font>
Cluttered?
Mine ain't cluttered at all.
WS6 Trans Am.
View My Ride @ thirdgen.org
Brinkkl2000
Aug 4, 2018 08:29 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
stalkier
Dec 6, 2015 11:25 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
kyle5647
Aug 15, 2015 11:56 PM
