Were do I start?
Old Nov 23, 2001 | 02:53 PM
Chris Sartori's Avatar
Were do I start?
I am trying to get my engine running smoothly and need some help from you TPI brainiac's. My engine has the following.
355ci, flat top pistons, Sportman II heads,
Comp Cams 12-404-4 (Lift .464, Dur .268op .276 closed), Heddman Headers, Accel Fuel Pump, K&N Air Filter,Stock 91 TPI setup with 7730 ecm. 19lb injectors. Adjustable fuel pressure regulator.
At present I have a rough idle with low vacuum. Engine wants to sputter and has little throttle response at take-off.
Any ideas on were to go and what to look for? I am a newbie to all this ECM stuff and learn a bunch from you guys. I appreciate your help and patience.
Chris
Old Nov 23, 2001 | 03:34 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
My initial thoughts are that you're in for a PROM change. Also, what is the LSA of the cam? 112 - 114 LSA should work fine for the speed density ECM. Any lower could cause erratic vacuume signals. (I think )
Old Nov 23, 2001 | 06:45 PM
WS6Formula350's Avatar
U may wanna check to see if your intake is sealed. If it's not then when u step on the gas u will be sucking in extra air and would make the engine sputter.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
