wont idle by itsself
Old Jun 6, 2008 | 01:23 AM
donaldw's Avatar
Car: 1988 pontiac trans am
Engine: 305 tpi
Axle/Gears: factory
i have a 88 ta 305 tpi and it wont idle by its self....i cleaned my iac and i think it is my tps...no codes...it runs great when u keep ur foot on the gas.....helllllp!!!!! please!!!!
thanks
Old Jun 6, 2008 | 04:44 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: wont idle by itsself
First, adjust the IAC and TPS properly, using this process (takes like 20 minutes):
https://www.thirdgen.org/tpimod2
That fixed my idle problems, and most likely is the culprit. The TPS is easy to check, you'll need a digital multi-meter though. You can pick one up for as little as $10 from RadioShack, Fry's, etc. Mine is a $10 cheapo digital one from Fry's, and it works great.
Old Jun 7, 2008 | 01:16 AM
donaldw's Avatar
Engine: 305 tpi
Axle/Gears: factory
i cant get it to idle by its self so how can i adjust the idle?...
Old Jun 22, 2008 | 05:03 AM
ace69247no13's Avatar
Car: 1991 z28
Engine: 350 .060 over 400 crank, 12:1
Transmission: t5
Axle/Gears: 2.73 currently
its the ignition pick up coil located in bottom of the distributor
Old Jul 9, 2008 | 01:11 AM
donaldw's Avatar
Engine: 305 tpi
Axle/Gears: factory
its not that it was my iac motor not responding...new one and it cured it
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
