the optimum fuel pressure setting?
Old Jun 6, 2008 | 02:13 AM
MADMAXGTA's Avatar
Car: 89 TTA
Just wondering what the optimum fuel pressure setting would be for my GTA with these related mods
1989 GTA 5.7 TPI
K&N filter
borla cat back
H.O. fuel pump
22lb flow matched SVO injectors
jet stage 1 prom
1.6 alluminum RRs
adjustabable FPR
3rdgen FTW!!
Old Jun 6, 2008 | 05:16 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: the optimum fuel pressure setting?
Probably pretty close to stock, which is around 43PSI. The 1.6 rockers and maybe K&N intake should increase airflow a little, but probably not much. Unless you have more airflow to match, more fuel won't really do much good.
Old Jun 6, 2008 | 06:06 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
45 PSI is my choice.
Old Jun 6, 2008 | 06:36 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Optimal can only be obtained with a wideband O2 sensor and ECM monitoring of the O2 voltage.
Best estimate without an wideband sensor, you still have to monitor your O2 voltage...at WOT you should try to adjust the FP for about 900-920MVs.
40 PSI won't aftect cruise, 45 PSI won't afffect cruise, but either pressue will and can affect WOT performance.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
