New Distributor? ...or?
Old Nov 23, 2001 | 10:19 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
The GTA is studdering a bit, we just changed the plugs and wires. Doesnt studder accelerating, but just cruising. Any ideas? Thanx
-Bud
<A HREF="http://albums.photopoint.com/j/View?u=1670288&a=13155057&p=47834932&Sequence=0&res=high" TARGET=_blank>1988 2.8L MPFI auto Camaro
</A> (bright red, not pink)
67 Camaro, being rebuilt. 383 6-71 blown etc etc
1988 5.7L GTA ---GTA's interior
Old Nov 24, 2001 | 12:05 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Did it start studdering before or after you changed the wires?
Did you change the cap and rotor?
Have you verified every cyl is firing?
I've had my share of ignition problems over the years. A timing light works wonders for
checking cyls.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
Old Nov 24, 2001 | 03:07 AM
age's Avatar
age
Car: 1992 Z28 1LE
fuel filter?
Old Nov 24, 2001 | 12:58 PM
Car: Camaro
Engine: 3800
It was studdering before the plugs and wires... thats why we changed them in the first place, but all we changed was the plugs and wires... not the cap and rotor. It seemed to have fixed the problem, but it didnt.
Havent checked to see if every cyl is firing no. Its just when you cruise.... not accelerating or idle as much.
The 2.8L studdered real bad one time and the wire was melted/burned... but that was just under a load, so I was thinking it shouldnt be the plugs/wires...
Havent checked the fule filter yet either.
The GTA is relativly new (w/ in the past few weeks or so) and its got very low miles. The tires were dry rotted and all so it was not driven hard at all. It was 100% stock and looked like the pic in the sig. So I dont know how often the guy changed anything. The plugs were rusted, but still fired well... little things like that to show that it was well taken care of/ not abused. No scrape marks on the nose, etc etc.
-Bud
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
