best cam for ZZ4 w/fully ported SuperRam
I spoke with a tech at Lingenfelter. He said if I got the cam made for the SR, it would be good for about 360 hp and 400 ft/lb of torque. Maybe I'm wrong, but doesn't this sound...weak? I was thinking about going to an lt4 HOT cam kit, but he said "his" cam was better (of course). I would like some feedback from you guys here: What is the best cam for a ZZ4 w/SR fully ported? What power numbers could I see?
I know several people that are very happy with the HOT cam. But Lignefelter also has some very good choices. Remember the TPI even with the shorter runner length of the Superram is big on TQ and not on HP so 360hp sound high to me but 400ft/lb sounds low.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,ZEX nitrous,Walbro 255lph f-pump,Accel AFPR,Random Technology catback,!cats,and mutch more.
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
The hot cam (Dur. at .50 218/228, lift .525 with a 1.6 ratio) has about the same specs as the LPE 219 cam (219/219 Dur. and .560 lift) which is intended for use with the super ram. I would guess there's not more than a 5-10 hp difference with the lingenfelter cam over the GM cam and that's because it has more lift. Yes, 360 hp and 400 foot lbs. sounds right for the motor mentioned. The main bottleneck are the stock ZZ-4 heads. With a good porting job done on them the hp may jump to 380. Putting a set of AFR 190's on the same motor would probably put the engine in the 400hp+ range, which would be awesome for the street.
Blk 89 IROC-Z, mods: 355 Super ram,forged pistons, ported and polished vette heads, LT-4 hot cam, Coan 700R4 trans and 2500 stall conv., Edelbrock tes headers and intake,Performance Resource custom chip, Flowmaster catback,no cat, and all that free stuff. Best 1/4 time on stock engine was 14.6 at 94 with catback, trans, tq conv., and free mods.
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
<font face="Verdana, Arial" size="2">Originally posted by camarojoe:
</font>
</font>
89 IROC-SuperRammed 355 w/ AFR 190's and LPE 219/219 cam-http://www.geocities.com/buckeyeroc
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
<font face="Verdana, Arial" size="2">Originally posted by 91-ZZ4-Z28:
</font>
</font>
Ok.... The flywheel specs on a ZZ4 are already 355 HP with 405 ft/lbs of torque.
I would think changing over to a bigger cam and 1.6 rockers would be good for more than
5 or so HP?
Unless you are saying that the Superram and LTR setup are actually decreasing HP?
I hope not, cause that's the setup I have in my car!
My 89 Formula
13.98 @92 mph 2.06 60 ft
1989 Firebird Formula, WS6 Package, ZZ4 Crate engine.
MSD 8.5mm Super wires, SLP 58 mm throttlebody, Edelbrock TES headers, SLP 3" SS exhaust,
Random Tech 3" hi flow cat, K&N filter, 700R4 trans w/ vette 2/4 shift servo, worked valve body, kevlar band,
2200 rpm stall converter, Borg Warner 9 bolt 327 rear (full poly mounts) Hotchiss panhard rod, Lakewood LCA's,
Spohn subframe connectors, custom chip, Walbro hi-flo fuel pump.
Accel stuff: 24 pound injectors, Superram intake, Large tube runners, billet distributor, supercoil.
In the works: 1997 Trans Am T56 Trans swap, Spohn crossmember/torque arm/driveshaft loop
