injector question
Old Jun 6, 2008 | 07:03 PM
jjskibbs's Avatar
Car: '89 IROC
Engine: 350 TPI 5.7L
Axle/Gears: axle?? got me.. 3.73:1 gears
injector question
i have reason to believe my injectors are due for replacing. i would like to upgrade and need some suggestions:
'89 iroc 305 tpi automatic: i heard the bosch type 3 24lb are good for a 350 and i can use them on a 305 with adjusted fuel pressure. anyone know about this?? milage/power etc... and any other changes i may have to make going larger than 19lb?? otherwise any suggestions??
Old Jun 6, 2008 | 09:00 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: injector question
Stay away from the 24lb/hr injectors...too much for your stock 305. Search for the correct ones I've had (but others haven't) had good luck with Accels...you need/want 19's to keep from fiddling with stuff and keep the ECM happy
Old Jun 7, 2008 | 06:33 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I put a set of ford bosch 19# in my car, and they're working great. It's slightly rich at WOT, but that can be fixed by lowering the fuel pressure, or with a tune. I chose them because of the price, I only gave $65 for them off ebay, freshly cleaned. Try searching ebay for 'ford 19 injectors', you'll get a ton of results. Also, the type 3 that you're referring to is the nozzle design. Mine are design 2's, but still give a better spray pattern than the stock ones.
Old Jun 7, 2008 | 08:40 AM
the blur's Avatar
IF your 305 has DUAL CATS, you need 21 lb injectors.
no matter what any one says !!!!
and ALL 89 up TPI cars got 21 lb from the factory.
This guy knows too:
http://www.scotthansen.net/customerinfo.html
Old Jun 7, 2008 | 10:54 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
This guy knows too:
the 1989 TPI got 19lbs/hr injectors, and not 21lbs...
all 305 got 19lbs and all 350 got 22lbs injectors..
MustangBeater20
Oct 29, 2022 09:20 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
