Recommended pushrods for Comp 268 XFI HR13
Old Jun 7, 2008 | 12:27 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Who is running this cam, and what pushrods are you using? I have a pretty standard bottom end 350 ZZZ with the above mentioned cam, afr 180cc heads. Engine builder says my stock length pushrods are too short, recommended 7.400" rods. What is stock length, 7.200"? Any info would be greatly appreciated.
Will
Old Jun 7, 2008 | 11:35 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Recommended pushrods for Comp 268 XFI HR13
Stock is 7.200" for a L-98 roller cam. However depending on the geometry and if he is using mid-lift 7.40" may be correct. Ask him if he is using the mid-lift method.
Old Jun 7, 2008 | 02:26 PM
norcalz28's Avatar
Thanks for the info
Pac J
May 17, 2020 10:44 AM
no green
Jan 9, 2016 09:22 PM
