Accel rail mount FP gauge
Old Nov 25, 2001 | 09:55 PM
IROCZ28TPI's Avatar
I bought one from Scamchargers for $52.99 and installed it. I went for a test drive around the block and came back to test for leaks. Upon checking, I noticed that fuel had begun to leak in the gauge by the dial.
I took it off and took it back.
Anyone else had this problem?
Old Nov 26, 2001 | 07:44 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Never had a problem.
Come to think of it, there is fluid in the gauge. My guess it's used as a damper for vibration, but it's not gas.
[This message has been edited by RCR (edited November 26, 2001).]
Old Nov 26, 2001 | 03:35 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I've never had that problem with mine. Only problem I had was over tightening the connector and causing a leak. POS brass fitting. Did you put teflon tape on the threads on the gauge that go into the L shaped brass piece?
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
9 bolt Borg Warner Rear (2.77's....oh joy) :P
6" rods, approx. 9.7:1 Compression, Stock TPI (soon to be ported), 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, 1.52 RR (for now), Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech 53,000 volt coil.
Track times to come.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
tazs2000
Jul 15, 2017 08:44 AM
mike_c
Aug 27, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
