what waterneck to use with edelbrock intake ?
Car: 1990 Chevrolet Camaro RS
This question sounds easy. I have a Edelbrock TPI intake and bought a new water neck from GM and it would not fit, I then bought an aftermarket waterneck and it did not line up either. What are you guys using that have the Edelbrock tpi base ? I am embarassed to be asking such what I think would be easy thing.
1990 RS Camaro 305 TBI, 700R4 Tranny, 3" cat back system with flowmaster muffler, Edelbrock strut tower brace, rear panhard bar, and torque arm, Spohn subframe conectors and lower control arms, all polyurithene bushing under the car, KYB gas adjust shocks and struts, March underdrive pully system, Taylor 8mm plug wires, Accel super coil, K&N air filter, Hypertech chip, GM Aluminum driveshaft, 3.42 Zexel-Torsen Rear end with superior 28 spline alloy axles, and Summit aluminum rear end girdle, cowl induction hood, Killer sound system, Many new mods to come (swap to 350 TPI comming soon)
Sounds like you did not purchase a TPI water neck. They are different than your TBI.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] www.MetzlerRacing.com
Best ET @ 1250 ft[*] 15.352 @ 91.215 mph (uncorrected)
GM part #14084383 TPI waterneck, I found the part # on this website:
http://www.metzcon.com/fbodymanual/0-64.htm
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I had to grind about 1/16 off the side and mine poped righ ton top. It would have fitted without grinding but it would have been jamed against the side.
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
You can grind off that stud tower and allow the stock TPI water neck to fit or take a standard TBI 305 water neck and place it backwards on the intake. Then get a top hose that fits. Trust me it keeps the hose away from belts, aftermarket air intakes and looks better.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
Thats Good info... I was ready to buy that intake also and would have been a little miffed that the stock waterneck didnt fit, since I have polished mine.
Hotrodboba400
Dec 10, 2019 07:07 PM
toronto formula
Sep 10, 2015 07:31 AM
