Help! Data log after injector swap.
Old Jun 9, 2008 | 05:37 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
Hey I'm still having problems with my injector swap. I'm about to switch back to my old injectors unless if I get this figured out. I got a data log of it idling. The prom was set to 24.00 but I wanted to see if setting it to 24.5 would help it any and it helped a little but still ran bad and smilled like gas. Also the belt is off the car I don't know if you can see that in data logging but just in case.
The injectors are Bosch design III. Please look at this data log and tell me whats wrong!! I'm still learning how to read these things but sense my car has not ran right I don't have a good example to learn from. The car is an 89 GTA 5.7 TPI with 24# injectors. Thanks for all the help you guys have given me so far and please keep it up
File Type: zip
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
Keiffer76
Sep 9, 2015 08:52 PM
Ranbo108
Sep 9, 2015 12:20 PM
