How do I know if I have a remote coil?
Old Nov 28, 2001 | 02:40 PM
Raptor Pilot's Avatar
I was aksed by the guy at Summit of if I have a remote coil or the coil on top of the distributor onmy 91 Formula 350...I looked under the hood and I see an ignition wire coming out from under the plenum extension to what looks like a coil...I know this sounds obvious, but I thought that the coil was always to mounted? Thanks for the help.
Old Nov 28, 2001 | 02:59 PM
Remondi2's Avatar
I believe your car came stock with a remote coil, but you shouldn't count on it still running the stock set-up. A sure way to tell would be to take off your plenum extension, by was of the 3 small torx bolts up top, and look at the distributer itself. A distributer with a remote coil will have 9 leads coming off of the top of it, one for each cylinder and one in the middle for the coil. A distributer with a integrated coil won't have the center lead, but instead it will have a rather large box type unit mounted in its place, that's the coil. Hope this helps.
Old Nov 28, 2001 | 03:01 PM
mtccl's Avatar
Check out my website. Picture of remote coil there.
87 TA, 305 TPI, Custom CAI, K&N, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler, 160* thermostat
The Phoenix Project..click to see my project car
Trans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Giocio
Oct 1, 2015 12:20 PM
