cam suggestions
Old Nov 19, 2001 | 03:23 PM
FstBrd6point3's Avatar
cam suggestions
ok, I am having a 383 built and need a suggestion for a cam. . it needs to be something that is mild enough for me to keep vacuum and still agree with the computer, but I love those crazy idles :-). . anyways, I am going to be running a 2500 stall converter and the 1.5 ratio roller rockers. . . any suggestions?? thanx
Old Nov 19, 2001 | 09:38 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
So far I'm happy with the SLP 51010 cam.
-- Joe
Old Nov 20, 2001 | 02:39 PM
86 IROC's Avatar
What are the specs on that cam Joe? I heard Comp Cams grinds their cams. I have a Comp Cams grind going in my 383. It is: 230 - 244 duration, .510" - .544" lift w/ 1.5 ratio rocker arms. They have a camshaft 1 step down from that one that they originally reccomended: 224 - 230 duration, .503" - .510" lift. Both cams have 112 degrees lobe separation.
You didn't say much about it other than "383, 2500 stall, good idle." Info about your cylinder heads, and induction system, as well as compression ratio, gear ratio - are also very helpful as well.
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
[This message has been edited by 86 IROC (edited November 20, 2001).]
Old Nov 26, 2001 | 03:32 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
LT4 HOT Cam.
Old Nov 28, 2001 | 01:48 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
224/230 @ .050" , .502/.510 with 112 lobe seperation on 108 centerline. 280/288 advertised duration.
Comp cams prolly does the grinds.
Old Nov 28, 2001 | 05:40 PM
bigals87z28's Avatar
Car: Check The Sig
can someone give me a good suggestion on cam and heads for my 305 tpi thanks fellas
junkcltr
Aug 2, 2019 11:12 PM
transamgta87
Sep 1, 2015 07:07 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
drathaar907
Aug 6, 2015 04:20 PM
