How would these parts help?
Old Jun 11, 2008 | 07:29 AM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Im planning on ordering some parts soon and im wondering how much theyed help or hinder me. I have a lb9 and right now it has just a magnaflow exhaust (4th gen) and a accel high perormance cap an rotor (not on yet). Im gonna order new wire plugs an headers
(http://store.summitracing.com/partde...?part=NGK-7401 plugs
http://store.summitracing.com/partde...part=MSD-31839 wires
http://store.summitracing.com/partde...rt=HOK-2055HKR headers)
i was wondering if that stuff would help me anything noticible. I assume it would but if those headers and my 3 in exhaust wouldnt that be to much flow?
Old Jun 11, 2008 | 07:37 AM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: How would these parts help?
91z 2 8,
As it pertains to the order of most gain would be the headers and then arguably the wires/plugs. Edelbrock has a set as well with the same diameter just depends on your budget. Also you might want to shot Dyno Don a pm at the socal section. He has a set that you could use just depends on if you are going to do any future mods.
As far as the plugs go, A/C Delco makes a very good set of plugs and they don't cost as much. Do a search.
The wires are good but you could also go with the 8mm to save a few dollars too.
So definitely headers first and check to see from the manu of the headers or the sales agent if you would need to use shorty plugs with them.
Take care,
Rabi C.
Old Jun 11, 2008 | 09:50 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
alrighty then thanks for the info. im not really planing on much mods to the 305 in the future i just heard hookers are good from everyone on here who has them say their the best for the money so im going with them. and ill look into the shorty plugs cause i heard that you need them with headers is that ture?
where these the acdelco ones you were talking about?
http://store.summitracing.com/partdetail.asp?autofilter=1∂=ACF%2D41%2D905&N=700+4294908216+4294908198+4294924928+4294925143+400721+115&autoview=sku
Old Jun 16, 2008 | 07:56 AM
onfire's Avatar
Car: 88 Formula 350
91z 2 8,
I have used the ac delco fr3ls but this is for aluminum heads and so it runs a bit cooler. Try to do a cross reference to see if there is a hotter range version of that short plug. Try to call the header manu or summit/jegs or local parts supplier. Or find the stock 91' 305 plug and see if they can find the shortie equivalent. Here is a link to see how to read a plug:
http://www.acdelco.com/parts/sparkpl...tification.jsp
The fr3ls doesn't have 2 numbers but they changed that id recently.
Sorry I couldn't be any more help. If you need more help pm me, do a search, or just post a question.
Rabi C.
Old Jun 16, 2008 | 08:08 AM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
alright thanks for the help if i need anything ill post a question or somin thanks
nate
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
