heads-intake compatability question?
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
So i just bought these '91 corvette heads and i wa told that they won't directly work with the intake that i have right now. the car is a 92 350 TPI.... Aren't they the same? if not it gives me an excuse to buy an edelbrock intake manifold... but the pockets are starting to feel a little light...
thanks
thanks
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: heads-intake compatability question?
Might want to check to see if your accessories will bolt up to the front of the vette heads?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Where in Cali are you located?
Please do a
for "l98 aluminum heads" or "corvette heads" or something similar. There are three major things you have to watch out for when using Corvette heads, and I've posted them several times as I used to run those heads.
Please do a
for "l98 aluminum heads" or "corvette heads" or something similar. There are three major things you have to watch out for when using Corvette heads, and I've posted them several times as I used to run those heads. Thread Starter
Car: 1992 Z28
yea im in South SF Bay Area= Santa Cruz
