Engine died :( advice on rebuild?
Old Dec 4, 2001 | 02:26 AM
Garett92Z's Avatar
hey guys
unfortunately my motor blew tonight. i press gas pedal and it doesn't even move (i know it's not trans. cuz engine doesn't rev at all and my trans was JUST pro-built)...
not the end of the world I wanna rebuild my engine anyways.
What should I expect for price to rebuild?
I'm looking to get about 300hp n/a out of the engine setup.... then i'm going to top it off with a 100hp shot of nitrous.
So i assume pistons are the big factor in the rebuild process with nitrous? I know it's all important and i'm going to be doing a LOT of research.... but what would you guys do in my position? I wanna spend about $2 000 rebuilding the engine and about $1 000 to port/polish heads.... and about $500 for a cam kit... basically i want to keep engine under $3 500... i think i can get at LEAST 300hp with that right?
thanks for ANY advice guys
garett
Old Dec 4, 2001 | 06:06 AM
ImportsRsloths's Avatar
EBAY!!!
Old Dec 4, 2001 | 07:32 AM
poncho9789's Avatar
Get quality products the first time and definately go with a forged bottom end and pistons. That way you can put quite a bit of nitrous to it to it and not worry as much. Also have the engine ballanced. With $3500 you could build one hell of an engine.
Old Dec 4, 2001 | 09:43 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
just buy a GM fast-burn 385 crate motor (long block only) you save money and hassle and have 385HP with a WARRANTY from GM!!!
Old Dec 4, 2001 | 09:10 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
LUNATI 383 SAYZ IT ALL!!!
Old Dec 5, 2001 | 11:18 AM
JaKeDaPlAyA's Avatar
<font face="Verdana, Arial" size="2">Is that 383 able to pass emmissions testing?
</font>
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
