Part throttle bog
Old Jun 17, 2008 | 10:12 AM
SupersportSteve's Avatar
Part throttle bog
I just started working on my son's 1987 TPI Camaro. It has a part throttle bog that I can't seem to get rid of. If you mash the gas, it runs good, but if you're taking off normally, it bogs and wants to die. When it's in overdrive and running at low rpm, it will surge. A friend with a scanner said it needed a MAF sensor, so I bought a used one, put it on, and the problem is slightly better, but still there. The car has new cap, rotor, plugs, and wires that my son put on. Just to make sure, I grounded out each plug with a test light and they all had a similar rpm drop. What's should I check next?
Old Jun 17, 2008 | 01:37 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Part throttle bog
The problem could be several things. I would check the following...
1. The TPS sensor to see if it has any "dead spots".
2. The fuel pressure at the rails.
3. Clean the IAC sensor of any carbon, etc.
Hope this helps!
Old Jun 23, 2008 | 10:00 AM
Thanks for the help, I keep getting closer, but no cigar yet. I checked and adjusted the TPS and it helped a bit more. Still a slight bog at part throttle, still wants to surge at low rpm in overdrive. I'm going to check EGR valve operation next, what else should I look for?
Old Jun 23, 2008 | 12:54 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Originally Posted by SupersportSteve
..... I'm going to check EGR valve operation next, ......
Bingo!
Pull and plug the vacuum line to the valve and see if the bog goes away.
Old Jul 9, 2008 | 07:28 AM
OK........I plugged the vacuum line to the EGR valve and it ran great for about 5 minutes. Once it got up to operation temperature the problem returned. If you accelerate when the rpms are below 2,500, it falls on it's face. Once above 2,500, it runs fine. I'm suspecting some kind of fuel related problem, but how come it runs great on hard acceleration above 2,500 rpm. Any insight or recommendations you can give me would be appreciated........this is starting to get under my skin!
Old Jul 9, 2008 | 08:37 AM
kfuss's Avatar
Not to hijack,
I have exactly the same issue, I will be interested to see what you have found.
I have:
replaced the IAC,
removed and capped the EGR,
replaced the TPS and set,
replaced the O2 sensor,
new high perf fuel pump (this is a conversion)
I get a code 44 and a hunting idle when in closed loop. This thing has me baffled.
Old Jul 9, 2008 | 10:01 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
i had the same problem with my modded 305. once i tuned it and adjusted the tcc points it stopped acting up.
Azrael91966669
25
Jun 20, 2017 04:04 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
1nastygta
Aug 8, 2015 07:38 PM
