Keeping TPI, Vortec or Fast Burn's
Old Nov 26, 2001 | 11:34 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
I have been searching the archives for info on this topic and have seen hundreds of posts and I guess I am more confused now. I have a '88 350 w/L98 heads and I am building up a 355ci with 9.5:1 compression, 4-bolt mains, hyperneutetic pistons, all balanced and blue printed. I am wanting to keep my TPI system and I am aware I might have to buy the SDPC TPI intake which is fine but... which heads should I go with? I want to make around 350HP, if more, thats cool. Will the SDPC intake work with both Vortec and Fast Burn heads. I saw on their website they had a basically all stock 350 L98 motor with new Vortec heads and their new TPI base intake pushing around 360HP. This sounds like the combo I want but is the $500 extra for getting into the Fast Burns worth it? I am wanting to go with a complete roller valve train and a hyd. roller cam of some sort, maybe a Hot Cam but not sure yet. Any ideas or suggestions will be greatly appreciated. Thanks.
Poor college student(donations welcome)
1988 5.7L TPI IROC-Z Hardtop, 700R-4, White ext. w/Gold/Black accents (soon to be silver), Black Custom Deluxe int., 4-wheel discs & G92 pkg. Car is all stock and original.
Best run: 1/4 14.90 @ 92.7 MPH
#3 Gone but shall never be forgotten. Long live the legacy of the man in black. RIP Dale Earnhardt "The Intimidator"
Old Nov 26, 2001 | 01:44 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
read my posts in the "after market product review" section on "fast burn heads", "1bad91Z", I think TimmyZ had a motor intake, cam combo post, they should give you an idea on a good TPI combo.
Old Nov 26, 2001 | 05:42 PM
Engine: LS1 V8
Thanks for the info 1bad91Z! That post is a wealth of info. The Fast Burns definitly sound good. I was wondering what intake I would have to get in order to keep my TPI? Would my TPI let the heads breath enough?
Old Nov 29, 2001 | 10:58 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You would need to get a Scoggin-dickey vortec TPI intake base. www.sdpc2000.com
This intake will bolt up properly to the fastburns and vortec heads. It also out-flows all of the standard style aftermarket TPI intakes!
Old Dec 1, 2001 | 01:30 AM
Earl 87gta's Avatar
I wish I would have had my SDPC bace flow tested I would like to compair the # my self.
87gta 355 fastburn heads,slp headers,flowmaster exhaust, LT4 hot cam and a lot more
Old Dec 1, 2001 | 05:28 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
G.M. Fast Burn heads are drilled for both vortec style and earlier 6-bolt style intakes. I think a factory TPI intake would bolt right up to the Fast Burn heads.
Old Dec 3, 2001 | 12:00 AM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
It may bolt up, but remember that the vortec and fastburn heads have raised intake runners. Sometimes there isn't enough material on the top of the port in the manifold to seal on the head. I would get the one made for those heads and avoid problems, but i've heard of a few people making a stock type inake work.
White '88 RS (originally 2.8)
Previous engine-350, .040 over, vette alum. L98s, stock tpi, stock 305 injectors & chip. TES headers & edelbrock cat back. 3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 357-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
New Setup:
4 bolt 357 (10.2:1), AFR 190s (fully cnc ported), LT4 Hot cam (1.6 RRs), Ported SuperRam (upper&lower), Ed Wright custom chip, 24# Accel injectors, Yank 3200 lock-up TC, 3.27 9 bolt rear, some traction! Hoping to see some 12s.
Old Dec 3, 2001 | 10:23 AM
Perry93TransAm's Avatar
Car: 97 WS6 T/A
Engine: LT1 383
Fast burns no doubt...they are some awesome heads, to further enhance them I would smooth the ports and blend the bowls (not taking a lot of metal out) remember heads are what makes the sucker run!!
Perry
Old Dec 3, 2001 | 12:39 PM
tpi_roc's Avatar
I agree, so far the fast burns seem to be some NIIIIIIIIICE heads
Check out sallee chevrolet online for some great prices on GM performance parts.
1985 Iroc-z, 14 second 305, new engine in the works.
Old Dec 3, 2001 | 12:47 PM
rockind78's Avatar
My vote if for E-Tec's. Base the intake port size on the cam you are using. If you are gonna drop $1100-1200 on fast burns then you might as well buy the E-Tec's.
Old Dec 3, 2001 | 02:47 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
rock - check out the Topics that I posted in aftermarket product review on "fast-burns" and "e-tec heads". I've done "ALOT" of research on cylinder heads, you may benefit from it.
Old Dec 4, 2001 | 11:13 PM
rockind78's Avatar
Read the topics in aftermarket review. You make a lot of good points. I am still learning when I speak (aren't we all?), but from what I can gather from flow numbers I have seen, the FB's DO outflow the E-Tec's...on the intake side, but the exhaust side is a whole 'nother story. I used Edelbrock and Jim Pace websites for the flow numbers. One thing I also like about the E-Tec's is that they ARE just like Vortecs. That's why I like them. Wouldn't you just LOVE to pick up a set of aluminum vortecs? Also, I like the fact that the intake runner cc is a little smaller on the ETec 200's than the FB's. That would promote a little more velocity of the charge and hence a little more low end torque. In the end though, people are just asking our advice. My money says that Chevyguy 1969 is gonna but what he is gonna buy, (probably Vortecs if he is a poor college student....don't worry dude, I am too ), your gonna buy what your gonna buy (based on what I am reading...FB's),and I am gonna buy E-Tec's. Hopefully WE WILL ALL BE HAPPY WITH OUR PURCHASES. Case closed.
Old Dec 5, 2001 | 11:16 PM
airdeano's Avatar
ummm why go wild on exhaust numbers?
if you are super/turbo-charged thatd be an
issue.
another issue is valvetrain.
lighter components are more desired. less rolling
resistance means less drag and more effiency.
and on upper rpms this is very cruical.
stainless is a fine valve material, but the
hollow titanium is lighter. just as durable.
one piece valves are heavy and at 6000+rpm
to keep the valve float to minimums heavy
spring pressure is needed. this isnt too good
on valve seats. just an observation.
airdeano
Fast355
Dec 2, 2016 06:33 PM
jharrison5
Aug 19, 2015 05:53 PM
legendaryhero7
Aug 12, 2015 06:19 PM
Sanjay
Aug 12, 2015 03:41 PM
