anyone get a flase code 32?
Old Jun 20, 2008 | 12:13 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i recently have been experiencing a code 32 once every few cold starts
car starts poorly like sounds like its choking then idles way up and calms down to normal
but during that hard/ rough start i get a engine code 32
if i disconnect the battery and start up again it doesnt come up
and doesnt come back while driving
anyone else experience this?
Old Nov 6, 2008 | 11:02 PM
mercdeking's Avatar
Car: 1985 Camaro Iroc-Z/Z28
Axle/Gears: 9 bolt borg werner, gears unknown
Re: anyone get a flase code 32?
Did you ever get a response?
I'm starting to get the same code and my car is hard to start when cold. Looking at some suggestions from my search, so I'm going to look at my egr line hookups and switch them, I've never known if I hooked them up correctly and no one gave me suggestions on my old post. But did you ever get this resolved?
Old Nov 6, 2008 | 11:22 PM
Bobby_80s's Avatar
Axle/Gears: no idea
my problem was that the wire to the egr wire temp sensor was pinched and being grounded under the fuel rail
this happened when i took apart the upper intake and fuel rail to replace my injectors
just had to snag the wire outa there and it was no longer grounded and presto no more code 32 for me
check all your connections make sure ur egr is working properly as well as ur egr solenoid
Old Nov 6, 2008 | 11:36 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
i only get it on long drives, like in excess of 50 miles, it happend the other day i pulled up to a light after driving all over the valley and i was feelin a little squirrley so i punched it and my engine revved, my tires hooked and i took off, about 20 ft off the line it choked and then the SES light popped but i just killed it in neutral and started it again and bam, no light. Its an fbody enigma in my book
Old Dec 6, 2008 | 05:52 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
plagues me as well
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
