Idle problem
Old Jun 22, 2008 | 12:30 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Idle problem
Been driving my car around for a few days and I have noticed a weird idle problem. Some times when I come to a stop and push the clutch in the car will idle at 1500 rpms. If I rev the engine a couple times it will come down to the normal 900 rpms. It doesn't do it every time but its consistent. It also wont do it on start up just when I come to a stop. Any ideas? Is the idle motor adjustable? I had cleaned it when I put the car together.
Info on the car
1986 Iroc
406
TPIS Big mouth intake setup
52mm Throttle body
Speed density computer with Howell harness
T56
Old Oct 7, 2009 | 12:47 PM
Chriznoznae1's Avatar
Car: 91 camaro z28
Engine: L98 350, Vortech heads, Lt4 cam
Axle/Gears: 9 bolt 3.27
Re: Idle problem
My car has been doing the same exact thing except I have an automatic. Did you ever figure out what was causing the issue? I've already replaced my ignition module, idle air control valve, egr valve, egr solenoid.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
