what controlls my timing
Old Jun 22, 2008 | 01:03 PM
89IROKCONVERT's Avatar
computer +_________
Old Jun 22, 2008 | 01:32 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: what controlls my timing
cam signal from the distibutor
Old Jun 22, 2008 | 03:37 PM
is that it?
Old Jun 22, 2008 | 07:25 PM
anyone
Old Jun 22, 2008 | 11:04 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
What do you want to know about the ignition system? The computer takes its signal from the distributor and modifys the coil signal in order to control the ignition timing.
Old Jun 23, 2008 | 07:39 AM
i want to know what could be making my car run at a ridiculously advanced timing . if i disconnect the bypass wire it should run at 8 deg and it wont
Old Jun 23, 2008 | 08:42 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The ignition control module will still provide rudimentary advance when disconnected from the ecm. If your idle speed is too high you may be seeing this advance. Try dropping the idle speed down with the ESC connector (four plug pigtail going to the rear of the dist) disconnected. For TPI engines there's another connector that can be disconnected that will do the same thing but you can pull the plug at the dist to be certain.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
justin57
Aug 20, 2015 07:05 PM
