injectors
Old Jun 23, 2008 | 08:20 AM
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
injectors
do the injector open with the electrical plus or close with it. if there isn't any pulse will fuel pressure open them. I tried a search, & didn't see what I'm looking for.
Old Jun 23, 2008 | 08:25 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: injectors
Fuelpressure should NOT open them, then they are bad. They shall always be closed if they not getting a signal to open.
Old Jun 23, 2008 | 10:06 AM
tshack's Avatar
Car: 87 Z28
Axle/Gears: 3:43
Re: injectors
So they are normaly closed.
Old Jun 23, 2008 | 06:02 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: injectors
When the injector is grounded out, it opens: otherwise it is always closed. At least, that is my understanding.
Old Jun 24, 2008 | 12:55 AM
Theking's Avatar
Car: 1989 IROC-Z
Re: injectors
Yes, always closed when not "in use"..
Old Jun 26, 2008 | 10:55 AM
tshack's Avatar
Car: 87 Z28
Axle/Gears: 3:43
Re: injectors
That was the way I thought they worked, I just wanted to be sure.
Old Jun 26, 2008 | 09:35 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: injectors
here you go
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
