Fuel Injectors
Old Dec 9, 2001 | 02:24 AM
matt_the_big_man's Avatar
Fuel Injectors
Does anyone know if you can switch the fuel injectors from a LS1 99 into a 87 IROC TPI?
Old Dec 11, 2001 | 03:38 PM
arthur's Avatar
I'm not sure if they will fit, but compare you engine size and HP output to the LS1. If you get and adjustable fuel press regulator, then using stock injectors are fine on a stock engine. Although I prefer the MULTEC style as opposed to the PINTLE style. All injector flow #s are at 43.5 PSI, measured in lbs/hour. The 305 has 19lb injectors, and the 350 has 22lb. More fuel for stock engine = very rich. At Wide open Throttle, the oxygen sensor is not used, and the mixture would be rich.
Old Dec 12, 2001 | 02:53 PM
bigals87z28's Avatar
Car: Check The Sig
hey i want to increase my fuel pressure to 50 psi should i get 24# injectors instead of my 19# on my 305? thanks
1987 Z/28
305 tpi
flame red w/black luver hood... ahh nice che bella
Old Dec 18, 2001 | 05:53 AM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
LS1 injectors are different than TPI's I believe the LT1's are the same though.
Old Dec 18, 2001 | 05:55 AM
Dano 00TA's Avatar
Engine: LS1/L98
1987 Z/28
305 tpi
Unless your motor is modded, you don't need 24 lb'ers. You can raise the pressure on your 19's to 50 however.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
