Has this been done?
Old Dec 13, 2001 | 03:35 PM
wikkidRoc's Avatar
Has this been done?
Can you swap Lt1 heads and intake on to an l98 and still mantain the origanal electronics? I have seen the lt1 intake swap done by its self, but would it save the headache of fabrication to just use lt1 heads as well. then the only fab needed is to drill the lt1 intake for a distributer.
Old Dec 13, 2001 | 03:46 PM
Momar's Avatar
I think that I have heard about it being done, but the heads require a LOT of fabing themselves. From what I have seen it would probably be easier to do it with just the intake and definately cheaper.
Ben
Old Dec 13, 2001 | 04:56 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
It can ,and has, been done, but the machine work involved is not worth it considering the LT1 heads are not that much better than AL L98s (i.e. any aftermarket head is better)
Old Dec 13, 2001 | 11:35 PM
Dan91Z's Avatar
Do all the water passages match up with lt1 heads???
and what all would be involved in making a lb9 capable of using a lt1 reverse flow water pump??? kinda intrested in this since i'm bout to add some boost.. :-)
Z28 Twin Turbo Project
