Orange SVO injectors
Old Dec 13, 2001 | 11:59 AM
Redi2RocZ's Avatar
Car: '86 IROC Z
Engine: 305 Tpi
Hi Guys
Probably been asked many times before but will replacing my standard GM injectors with Orange 19lb F**d items cause me any problems?
My 305 Tpi is stock
Any replys gratefully received
Old Dec 13, 2001 | 01:21 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
They will function just fine. The only problem is the ford injectors are rated at 37 psi, GM injectors are rated at 43 psi. This means that the ford injectors will actually be 7.8% richer than the GM injectors.
This may or may not cause you problems...
Old Dec 13, 2001 | 03:07 PM
Redi2RocZ's Avatar
Car: '86 IROC Z
Engine: 305 Tpi
Thanks Ed,
What sort of problems do you mean though???
Old Dec 13, 2001 | 07:16 PM
91'firebrd's Avatar
Might be rich at WOT, computer should be able to compensate during part throttle.
Old Dec 14, 2001 | 10:24 AM
leirch's Avatar
You get X amount of fuel with the stock injectors, putting in X amount more fuel over the top of what stock is expecting is going to cause an overall rich condition, not just at WOT.
Brendan
1987 IROC-Z, engine, tranny, and other "stuff"
92-Formula
Dec 12, 2015 10:34 PM
gta892000
Sep 16, 2015 12:37 AM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
