Fuel setup for TPI conversion on '76 Blazer
Old Jul 5, 2008 | 05:44 PM
drewnashty's Avatar
Can I use the existing stock fuel tank? If not can I use a fuel tank from the TPI f-bodies?
It has an external pump can I just swap that with an EFI one or do I have to have an In-Tank fuel pump?
For the return lines can I just make a T line before the pump or does it have to return to the tank.
Thank you.
Old Jul 7, 2008 | 09:18 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Fuel setup for TPI conversion on '76 Blazer
return to tank-heat issues
Old Jul 7, 2008 | 11:22 AM
drewnashty's Avatar
Thank you
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
