EGR SOLENOID HELP....
Old Jul 9, 2008 | 12:02 PM
crew4aj's Avatar
We have a 1987 Iroc 5.0 5 speed and the egr solenoid is bad, we have checked with the dealer, auto zone, napa, yearone and not avalible.
Is there anyone who knows where to get one, or which one will interchange?
We need to have car smogged
Old Jul 9, 2008 | 12:09 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Re: EGR SOLENOID HELP....
http://www.partsamerica.com/ aka advanced auto parts
Old Jul 9, 2008 | 12:59 PM
crew4aj's Avatar
It shows in listing but no stock at all. Still unable to locate
Old Jul 9, 2008 | 01:45 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
it shows they can have it in 1 day if you go to the store and pay for it or order it online . if that is to long i guess you out of luck , thats not a high order part for them to have it on hand so they keep them at their warehouse .
Old Jul 9, 2008 | 01:58 PM
GTA90X's Avatar
Car: 1990 GTA
Engine: stock L98(being pulled for rebuild)
Transmission: stock 700R4
before you buy it or any other part for that matter, be absolutely sure that is what you need. At one time, I was constantly getting an EGR failure trouble code on my '90 5.7 TPI. On the advice of a friend who is a GM dealer mechanic, I checked my injectors. He said there are multiple "indirectly related" problems that can set an EGR code. I had one injector that was definitly bad, and one that was questionable. Changing the 2 bad injectors fixed my EGR code.
I hope you don't end up chasing a problem all over the vehicle, as we all know can happen. Good Luck..
Old Jul 9, 2008 | 02:00 PM
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
ya , put an ohm meter on it , if it is below 20 ohm it is bad . also check that it holds vacuum .
Old Jul 9, 2008 | 03:58 PM
crew4aj's Avatar
its wrong...i called to order and they dont have any in stock
im sure. I have vaccume to solenoid, wiring is good, egr opperated when using vaccume pump. shield is broken around solenoid
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
