Popping or backfiring at 4k and up
Old Jul 9, 2008 | 06:40 PM
nj85z28's Avatar
Car: 1986 Monte Carlo SS
Engine: TPI
Transmission: Level 10 700r4
Hey guys. Looking for some help here. About 2 years ago I swapped an 86 TPI T/A engine and trans combo into my monte carlo ss. it ran beautifully. in the last 2 months im getting a loud popping, or backfiring around 4k rpms. I understand that it could be anything im sure, but so far ive checked and/or replaced the following-
cap/rotor
ign. coil
icm
wires
plugs
ESC module
MAF
engine wiring
Ive been doing alot of reading at chevythunder as well and that site is saying it could be the knock sensor. Could this be true? Im on my second MAF and its still throwing me a code for the MAF randomly.
Old Jul 9, 2008 | 07:20 PM
GTA90X's Avatar
Car: 1990 GTA
Engine: stock L98(being pulled for rebuild)
Transmission: stock 700R4
Re: Popping or backfiring at 4k and up
When does it backfire? When the throttle is open or when you let off?
Old Jul 9, 2008 | 07:22 PM
nj85z28's Avatar
Engine: TPI
on acceleration around 4k. probably starts at about 3800 rpms
Old Jul 9, 2008 | 07:35 PM
Average Joe's Avatar
nj85z28,
We are having the same problem. My car will pop when I hit the n2o. runs OK without,,,,but it has a kind of surge without the laughing gas. I noticed when I rev my car in park, the car kind of .....falls on its face @ 5500rpms. Not the kind of fall on your face that's normal, it surges.
I'm wondering what your car does when you rev it in park?
Is your car popping out the exhaust? or intake? Kind of important to know. out the exhaust = fuel, intake = lean.
Old Jul 9, 2008 | 07:38 PM
nj85z28's Avatar
Engine: TPI
its popping in the intake and will do it in park if revved high enough. thanks
Old Jul 9, 2008 | 08:30 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
what kind of timing are you running with the est unplugged? If you are running anything more then 6* with the stock ecm its going to add that much more at every point in the spark advance table. I would suggest either backing down the timing or change the base setting in the computer
Old Jul 9, 2008 | 09:07 PM
nj85z28's Avatar
Engine: TPI
ill look into that thanks
Old Jul 10, 2008 | 12:33 AM
I'm gonna guess your running your timing to far advanced or low octane.
Old Jul 10, 2008 | 06:28 PM
nj85z28's Avatar
Engine: TPI
im running 93 octane and have never touched the timing
Old Jul 22, 2008 | 04:45 PM
nj85z28's Avatar
Engine: TPI
this is still an issue..anyone?
Old Jul 24, 2008 | 07:55 AM
vetteboy86's Avatar
So is it popping through the exhaust or the intake?? I have an issue with popping in the exhaust? I wonder if our issues aren't timing related. I am going to have to do some reading to determine which though. Mine might be advanced, and yours might be retarded in that it is igniting the fuel mixture while the intake valve's are open.
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
Lmancha96
Sep 25, 2015 08:11 PM
