weird noise from the new engine.
Old Jul 10, 2008 | 12:35 AM
ssj2link's Avatar
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
hi, just finished swapping my L98 tpi motor in my car. im having a problem now. when i start up my car first off it is kinda hard to turn on. it kinda chokes. also form some reason its making a very weird noise when its one sounds almost like the pistons are hitting the valves but i cant be sure it gets louder when i give it the gas. might be an exhaust leak form the headers but should it be so loud?? im very lost and confussed. also i dont have the o2 sensor hooked up just yet, could that be a problem?
Old Jul 10, 2008 | 08:02 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: weird noise from the new engine.
Check your timing.
Old Jul 10, 2008 | 09:51 AM
ssj2link's Avatar
Engine: 5.7/5.0
how do u actually do the timing? i know that u unplug the est wire but what should the TDC be at, like what number? i have an LT4 hot cam btw
Old Jul 11, 2008 | 09:25 PM
xpbxwrecked1's Avatar
Car: 87 mustang gt 89 camaro
Engine: 302 355 tpi
Transmission: manual
Axle/Gears: 3.55 and 3.42 posi
at first just turn the distributor until the engine runs smoothly then use a timing light to get it perfect.
David Frans
Oct 31, 2015 08:12 PM
mattcanty
Oct 12, 2015 11:08 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
