will not run fuel problem HELP
Old Jul 10, 2008 | 04:33 PM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
i wrote a forum awhile back but i did not get any responses so lets try it again. i have a 1987 iroc-z camaro 305 tpi automatic. i just got the car off the previous owner who installed a fuel pump, drove it a few miles and it died out but started back up immediately and they drove it home. But it would not start the next day. i got the car charged the battery, and went to start it, it will run for a fraction of a second and then die right off. if you spray starter fluid in it it will stay running until the starter fluid burns off. i have changed the fuel filter, fuel pump rely, and i am getting 41 psi pressure on the fuel rail. i have tried switching the ecm with my running 305 tpi iroc-z which is also and 87 but that didn't help either. really i am out of ideas. can any one please help? does anyone have and ideas on what could be bad and how to check it?
Old Jul 10, 2008 | 04:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: will not run fuel problem HELP
Have you checked the injector pulses with a noid light?
Old Jul 10, 2008 | 04:37 PM
Engine: 305 tbi
that i have not yet i do not have 1 but i guess i will go to advance auto parts and get me 1 and try it
Old Jul 10, 2008 | 05:03 PM
Engine: 305 tbi
called 3 auto parts stores no 1 even no what a noid light is i can get 1 off line but it will talk 2 weeks to get i have had that car siting fr over 30 days no because i have never had a dumb problem like this befor shame to the car is cherry all there and all orignal yellow Iroc-z
Old Jul 10, 2008 | 05:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Try asking for an injector test light intead.
Old Jul 10, 2008 | 08:18 PM
Engine: 305 tbi
nope still dont have it i guess i will get it off ebay so if the light does not light up what do from there
Old Jul 10, 2008 | 08:36 PM
Tonysz383's Avatar
Car: 88 IROCZ 350
Engine: 355 cu TPI
Transmission: 4L60 w/ 3200 stall
Axle/Gears: 9 bolt W/370 gear
Did you check the injectors with an ohm meter? Get a reading acoss the pins and should read between 12 to 15 ohms. If you don't get this values the injector is bad. Bad injectors will make the engine will act funny.
Ghettobird52
Jul 5, 2024 11:18 PM
bryan623
Mar 22, 2021 06:43 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
