After new plugs and wires car won't idle
Old Jul 9, 2008 | 10:12 PM
uc360's Avatar
Car: 1988 Firebird Formula 350
Engine: 5.0L TPI v8
Transmission: 5 Speed T-5
Axle/Gears: 3.08
Hey all,i have a 1988 firebird t/a formula 350 with a 305 tpi engine, and i just installed a new set of oem spark plug wires, and spark plugs and now the car won't idle, and it idled fine b4 i changed the spark plugs and wires, i did some re-routing of the wires to keep them away from my headers as that was the reason for changing the wires because some of the plastic clips broke and the wires fell onto the headers...could i have done something while i was re-routing the wires?, any help would be great..
Old Jul 10, 2008 | 03:20 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: After new plugs and wires car won't idle
loose, disconnected vacuum line maybe?
Old Jul 10, 2008 | 08:15 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Check that all of the plug wires were put on in the correct location (firing order).
Old Jul 10, 2008 | 11:02 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
yes x2 on both replys.
Check to make sure BOTH ENDS are connected.
If you have to, take them off...and snap them back on.
Check and make sure you didnt knock off any vaccume line or sensor wires.
And please double check the firing order.
1-8-4-3-6-5-7-2
check the wires.
Old Jul 10, 2008 | 05:15 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
as said in previuos posts, check wires and firing order..
Also check so the conections into the distributor wasnt touch or loose.
Old Jul 10, 2008 | 09:43 PM
uc360's Avatar
Engine: 5.0L TPI v8
Axle/Gears: 3.08
thanx guys for all the posts, and good info, turns out i did it all correctly, but for some reason, the car decided not only did it want new plugs and wires but it also wanted a new pick up coil, replaced the coil and vwela, idles great now...sometimes i think if this site wasn't here i'd be so lost, and it would probably hurt the pocket book more too...thnx again guys for the help...
Old Jul 11, 2008 | 12:28 AM
HCR13's Avatar
Car: 1987 Trans Am
ah yes, the beauty of owning a 17 year old car!
Old Jul 11, 2008 | 07:51 AM
Theking's Avatar
Car: 1989 IROC-Z
Yeah the pickup and/or ignition module is pretty common to, to be bad...
Those ones can cause alot of trouble...
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Exxon Limited
Aug 9, 2015 08:13 PM
92projectcamaro
Aug 6, 2015 01:20 PM
