3 wire O2 sensor
Old Jul 15, 2008 | 10:20 AM
Chevhead89's Avatar
3 wire O2 sensor
got a 91 tpi system with a 1 wire O2 and i put headers on the truck and bought a 3 wire bosch 13077 and i was wonderin which wire goes where and does what. because theres 2 whites and 1 black. i know ones a ground, ones a hot and then the actaully sensor wire. but help would be apprectiated. thanks
Old Jul 15, 2008 | 03:11 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: 3 wire O2 sensor
If you're looking at the 3 wire connector I'm pretty sure the sensor wire is the center wire. A continuity (ohm) test should tell you for sure.
Old Jul 15, 2008 | 03:50 PM
Chevhead89's Avatar
nope i figured it out. the black one was the sensor, middle was ground and other power. but thanks
Old Jul 16, 2008 | 07:01 AM
Mongoose's Avatar
Car: 90 Formula
That's cool. Last time I replaced mine I wired it up with a GM pigtail so I don't have to remember which wire is which anymore.
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
dbrochard
Sep 19, 2015 08:13 PM
