Street Radial PSI
Old Jul 22, 2008 | 08:30 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Street Radial PSI
I know that I should adjust at the track, but what would be the ideal psi for running a set of mt street radials 255 50 16's. I started at 20 and worked down to 13. At 15 psi I ran a 1.76 60 foot and a 12.53, When I went down to 13 psi I ran a 1.75 with a 12.7. WTF?
Old Jul 23, 2008 | 09:07 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Re: Street Radial PSI
What was your mph if I can ask?
As for why you slowed down with a better 60ft, lots of things could be a factor, heat soak, air temp etc. but assuming nothing else changed, you could have reached the point where the lower PSI starts to add enough contact patch that the friction slows the car down a hair.
Old Jul 23, 2008 | 02:16 PM
ScottyRock's Avatar
Car: 92 L98 Z28 Heritage Hard Top
Engine: L98 350 w/ HSR,24lbs inj,AFPR
Transmission: TCI Super Street Fighter W/3300 sta
Axle/Gears: 3.73 Detriot NoSpin,LPW cover
the lower PSI starts to add enough contact patch that the friction slows the car down a hair. What he said........
Old Jul 23, 2008 | 05:31 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
110
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
FormulasOnly
Jul 23, 2018 08:47 AM
cheesehomer
Dec 31, 2015 08:48 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
dusterbd
Sep 29, 2015 08:40 AM
