Does your fuel regulator "tick"? also a surge.
Old Jul 22, 2008 | 10:08 PM
B4Camaro91's Avatar
Car: Stock 1991 B4C Camaro
Engine: 5.7 TPI
Axle/Gears: Stock 2.73
'91 w/5.7 77k miles has a surging problem also. I noticed my fuel regulator makes a ticking noise that seems a little loud to me. Does yours?
Here is what I've also noticed:
1. Key off at idle 40psi.
2. Running at idle fuel 30psi, vacuum 20lbs.
3. While driving fuel 38-40psi, vacuum 0lbs.
4. Fuel injectors check good. 17.2 cold and 17.9 hot
I thought the loud tick was from my cap and rotor but its the fuel regulator. I can also feel the "pulse" of the tick in the pressure gauge hose.
My surge is as I drive, mostly 2000rpm, no codes. It all started after I was playing around "gunning it" by tapping the throttle making the car jump a few times then I went about 100-110mph and as I went back down to 65 I noticed the surge. The car will still pull but it also surges as it does.
Ive replaced the cap and rotor and know I need plugs and wires but i dont think they would cause this surge.
So what do you think?
Old Jul 23, 2008 | 07:16 PM
IroczInOz's Avatar
Re: Does your fuel regulator "tick"? also a surge.
I am also looking at a fuel problem. One thing I noticed that you have the same fuel pressure at idle as what I do basically. I think 30psi at idle is too low?? I would have thought it should be around 36 and as you increase load it should climb up to max 44PSI.
One of the reasons I am trying to find a fault because of the low fuel pressure I think.
Old Aug 1, 2008 | 06:08 PM
B4Camaro91's Avatar
Engine: 5.7 TPI
Im wondering if my knock sensor would pick this up this tick and and adjust the spark to cause my surge?
My other thought is my car always reads low temps.maybe the thermostat is cracked open causing it to not warm up which causs it to run rich which causes it to foul up the egr? Just a thought.
Old Sep 22, 2009 | 09:14 PM
mrlipps's Avatar
Car: 1990 GTA
Engine: L98 350 Dart Heads 268XFI Super Ram
Transmission: WC T5 Hurst Shifter
Axle/Gears: 3.42 Posi
I have the same pressure / ticking problem you did
Did you ever figure out what it was?
Bad regulator?
Old Sep 23, 2009 | 07:50 PM
B4Camaro91's Avatar
Engine: 5.7 TPI
This year Ive only had the car out a few times. After sitting for about 5 months during the winter months it hasnt made the surge. It still makes the tick. I dont drive it often at all but still hope to replace the regulator sometime. Good luck with yours, Ill let you know if I find anything.
I want to replace my regulator, plugs, wires, egr and regulator.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
