Stockish TPI 305
Car: 1983 G20 Chevy
Transmission: 4L60
Stockish TPI 305
I recently pulled the Vortec/SDPC BASE/SLP runner combo off of my van for use on a different project and in my parts inventory had a pair of stock 187s and a stock TPI setup. Here is the end result. It runs great on 87 octane had decent power, TONS of torque and gets very good gas mileage when I am not ******* on it. 20+ MPG in a fullsize G20 Conversion Van. It has a severe lack of power above 4,500 rpm though. This engine is choking over dead right were the old combination was just getting turned on, even though they both have the same shortblock, cam, and exhaust.
http://s243.photobucket.com/albums/f...t=101_1403.flv
http://s243.photobucket.com/albums/f...t=101_1402.flv
http://s243.photobucket.com/albums/f...t=101_1400.flv
I was surprised to see that the TBI heads wanted even less timing than the L30 Vortecs that were on it before. I might add that the Vortec heads were running on 1 point higher compression than the TBI heads as well.
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: Stockish TPI 305
I'd bet a dollar to a dime that the heads alone are 80-90% of the difference in power band loss. I have to believe that on a 305 the stock tpi intake is close to good enough.
Car: 1983 G20 Chevy
Transmission: 4L60
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
