TPI Intake Versus LSX Intake System
Old Jul 23, 2008 | 10:53 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
As most of you know GM went from a TPI style intake system to a LT1 intake to a LSX intake system.
IMHO the TPI and LSX style intake systems are basically the same concept. The runners on each are shaped like a candy cane and feed from a plenum located in the same area versus the runners. The throttle bodies are in the front on both systems. The LSX is packaged tighter due to the shorter length of the runners and the use of plastic technology. So by modifiying the TPI intake system as we are we are actually updating it to an LSX style if you will.
IMHO the HSR and Mini Ram intake systems are in the same family as the LT1 intake system. So to stir the pot it looks like GM went back to the TPI intake system as being the all around best way to do things.
Old Jul 23, 2008 | 11:26 AM
Guest
Guest
Posts: n/a
Re: TPI Intake Versus LSX Intake System
I suppose in theory you could say that. The LS1 is a lot better design overall though... mostly because they eliminated issues with transitions that the TPI fails miserably at.
Old Jul 23, 2008 | 12:32 PM
Car: 1989 GTA
Engine: 369 TPI
MadMax what you say is true. However with what we are doing with the TPI I think we are "approaching" that of an LSX intake. Shortening the runners to the LSX length and making the transitions better. IMHO the GM engineers just updated the TPI manifold.
Old Jul 23, 2008 | 12:46 PM
Stephen's Avatar
Car: 87 GTA
Yep....It kinda seems like the LSx is "simply" a "reverse image" of a TPI. Still runners, shorter overall, but kinda like putting the plenum under the runners instead of above them.
Old Jul 24, 2008 | 11:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If TPI engines had 18 degree heads that flow 300 cfm, and straighter runners, we'd be just as fast as LS1's are stock.
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Sanjay
Aug 12, 2015 03:41 PM
