heads and cam for a 305 tpi
Old Jul 31, 2008 | 11:14 PM
fastfirebird's Avatar
Car: 91 Firebird Formula,2 1979 T/A's
Engine: 5.0 TPI, 403
Transmission: 700r4,turbo 350
I have a 91 formula with the 305tpi. I'm trying to figure out what heads and cam will work best with it. I have already purchased headers,flowmaster cat back,had my pleneum ported, accel runners,injectors,afpr I will be getting a different intake as soon as I figure out what heads to get. I'm debating between torqer heads and the gm performance vortec heads and was thinking about the zz4 cam. any suggestions besides building a 350?
Old Jul 31, 2008 | 11:24 PM
F-Body Demon's Avatar
Re: heads and cam for a 305 tpi
If your getting a new intake already I say its Vortecs for the win! Cant beat the value and they work great right out of the box. As for cam I would get something in the 214 duration range for a 305 that has a TPI. But thats as high as I would go. I had a 204/214 duration cam in my LG4 a while back and it went up to about 5500 really well, which is all your TPI is going to want any way. Sure you might make more power peak with more duration but your going to loose your tq and average power.
Just my $.02
Old Aug 1, 2008 | 09:15 AM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
the trick flow heads for the TPI are supposed to be pretty nice
if you are changing intake, go vortec
i put the edelbrock tpi heads on her car, i didn't know about the vortec at the time, however, on her 350, WOW, night and day difference.
heads make/break the car, not to mention aluminum saves weight too
Old Aug 2, 2008 | 02:07 AM
I was leaning toward the vortecs but they are made for the 350 and have larger combustion chamber I think 64cc and the 305 runs 58cc I think I was worried that going larger I would lose compression and also maybe have clearance issues with the valves.
Old Aug 2, 2008 | 09:24 AM
Don 79 TA's Avatar
Engine: TPI
I thought the trick flow heads were 56cc or 54 cc
which should be perfect for the 305
not to mention with good tunning could also use 87 octane and it would run fine
i am not 100% sure, but depending on how much valve lift you have the 64cc heads might be fine, but i would get confirmation on that, and yes, you will loose some compression, but the head flow can make up for it, albeit at the cost of the TPI flowing air
http://www.trickflow.com/partdetail....7&autoview=sku
that should do the trick
56cc
175cc flow
Old Aug 4, 2008 | 08:47 PM
Those are nice heads but costly. I was hoping to come in around $800. Other than being aluminum and lighter what advantage do these have over the torker s/r's? They should be comparable right?
Old Aug 5, 2008 | 09:39 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Get the 305 vortecs or have the 64cc ones milled down to get the chambers to 58cc's....... Problem solved.
84z96L31vortec
Aug 20, 2017 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
drathaar907
Aug 6, 2015 04:20 PM
