what is your vac in hg at idle
Old Aug 3, 2008 | 12:31 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I know this will vary a bit due to the modifications on every engine. But I am noticing my car idles at 700rpm @ 16hg's. I am trying to get my engine to use a bit less gas and am wondering that since I lowered my rpms from 800 to 700 has actually increased my vac? I have always had this setup idle at 700, so I dunno what my vac would be at 800.
Can some of you chime in and tell me if your auto/manual, warm idle rpms, and your vac in hg's.
Thanks!
Old Aug 3, 2008 | 08:07 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: what is your vac in hg at idle
My '87 5.7 TPI idles at 700 w/ 20". Yours seems low.
Old Aug 4, 2008 | 12:05 AM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
Transmission: 4 spd auto
89 5.7 tpi mild cam. intake, as&m runners, base timing at 8d, idle programmed in at 750, vacuum 17 to 18". Lots of folks on this site with mild setups are in the 16 to 18" range-not all that bad.
Old Aug 4, 2008 | 04:56 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
92 383 not so mild cam.
15" warm 700 idle.
Old Aug 4, 2008 | 07:32 AM
Dale's Avatar
Engine: 350 S-TPI
So mine is a bit average to just a hair low. Think its worthy of playing around or just leave it?
Guess I got use to my L67 that is 22@600
Old Aug 4, 2008 | 10:02 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
question....how do U come up with these numbers?? Is there a tool to test vacuum?
Old Aug 4, 2008 | 11:27 AM
Dale's Avatar
Engine: 350 S-TPI
Yea, I have one mounted in each of my cars 24/7. Plus there is a test tool for temporary use.
Then I am programing my pcm myself, so I know where the car idles +/-25rpm.
Old Aug 4, 2008 | 12:17 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
all I see is a boost gauge and a air/fuel mixture gauge. What the test tool for vacuum look like?
Old Aug 4, 2008 | 12:21 PM
Dale's Avatar
Engine: 350 S-TPI
the boost is also a vac. One side of 0 is vac, one side is boost.
Its very hard to find a vac only, and they are not marked as well.
stand alone temp..
http://www.iequus.com/product_info.p...tegory_id=1_30
dash mount..
http://www.iequus.com/product_info.p...ory_id=100_105
Old Aug 4, 2008 | 01:27 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
on that first one, what do I plug it into...just any vacuum hose in the car??...Any particular place?
Old Aug 4, 2008 | 02:40 PM
Dale's Avatar
Engine: 350 S-TPI
Either one, you have to splice into a hose as there is nothing you can disconnect that wont cause the car to idle differently.
Do not tamper with your MAP one, it needs to be smooth shot.
You can not tap into the one from the purge canister. It will cause twitchy readings.
This leaves
FPR (easiest and correct size)
Brake Booster
PCV
Make your own port.
Anyway, back to original question. Anyone else know the readings of there setup?
Old Aug 4, 2008 | 04:13 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
415" 9.0:1 big cam 9" hg (70kPa)
415" 8.7:1 smaller cam 12"Hg (60kPa)
/N.
Old Aug 19, 2008 | 09:14 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
I have not checked the 327 since I put the roller cam. But-
327, 0.462/0.482", 219/229@0.05, 10-11" at 850 idle
69GTOby
Apr 18, 2016 02:34 PM
92-Formula
Dec 12, 2015 10:34 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
rjcme
Sep 5, 2015 01:23 PM
