Code 43 and 42
Old Aug 4, 2008 | 03:04 PM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Code 43 and 42
Hi!
We pulled in a 305 tpi speed density engine in a astro whith a painless wiring.
I canot get rid of the code 43 and 42,we change alot of things,esc,ecm,and more,the car runs fine but just on the rich side.
The problem is that i canot read the ecm by datamaster the DTC is red and the connection are comming on and off all the time.
Any clue?
Thanks!
Old Aug 4, 2008 | 03:53 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: Code 43 and 42
Speed Density doesent use ESC its on the Memcal on SD setups, did you change the Memcal? or do you have a ESC?
Code 43 is ESC error so does the car have a ESC unit ot is it a Speed Density setup?
Code 42 is EST error, check so that the brown/white Wire from the dizzy is connected.
Go to www.chevythunder.com there you will find flowcharts of the error codes. "troubleshooting flowchart link"
/N.
Old Aug 5, 2008 | 05:06 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Re: Code 43 and 42
check the knock sensor and the wire harness to it. the knock sensor should have about 3500 ohms resistance when checked from terminal on sensor to ground. if it is open or less then 3500 replace the knock sensor. if it reads correctly check the harness
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
