View Poll Results: Which cam would you run?
Crane Cams Grind# 2032
60.00%
GM LT4 Hotcam
40.00%
Voters: 5. You may not vote on this poll
What's your Advice?
Old Aug 6, 2008 | 03:15 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
What's your Advice?
Which cam do you think I would be more likely to reach my goal of a 350-400 horsepower motor at the flywheel? My car is an 87 350 TPI with all free-mods. Edelbrock Headers, no emssions,smog,or a/c
And I have the spring kit that comes with the LT4 Hotcam(got in a deal)
My two cam choices are
Crane Cams grind #2032 or the LT4 Hotcam?'
What power numbers can I expect from the two cams?
Old Aug 6, 2008 | 04:14 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
Re: What's your Advice?
I had the 2032 in my 305 before I switched it and it was a good cam. I am not to crazy about it for a 350 but I like it more than the HOT cam. Here are the specs
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 301 @Valve 452 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 310 @Valve 465
Rocker Arm Ratio 1.50
Cam Timing: -- @---
Lift: Opens Closes ADV Duration
Intake --- --- 270 °
Exhaust --- --- 276 °
Spring Requirements: Triple Dual Outer Inner
Part Number 96802
Loads Closed 107 LBS @ 1.800 or 1 13/16
Open 276 LBS @ 1.360
Recommended RPM range with matching components
Minimum RPM 1800
Maximum RPM 5800
Valve Float 6400
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 0.0 BTDC 34.0 ABDC 107 214 °
Exhaust 47.0 BBDC (7.0) BTDC 117 220 °
Good mid range cam should work good in you lightly mod'd 350
Who knows on the HP, I think though for that target HP rating the hot cam may be better to reach that goal but as of NOW the Crane is a better choice. I may be wrong so someone can correct me if I am.
Old Aug 7, 2008 | 10:39 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Are you gonna have the heads off and machined???? Are you keeping the stock TPI?????
Old Aug 8, 2008 | 01:31 PM
Car: '87 Iroc-Z
Well, I plan on ditching the head eventually, but stock for now with an LT4 Spring Kit,I do plan on using a TPIS Bigmouth intake along with extrude-honed Edelbrock Runners also with custom chip. LMK what you think
Thanks!!
BTW I know the specs of both cams!!
Old Aug 8, 2008 | 03:31 PM
Car: '87 Iroc-Z
bump, Hey guys get in on this! I need your help and this group of guys on this board,has always had my respect for their knowledge
Old Aug 9, 2008 | 11:29 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Looks like you don't have a choice then........... Crane 2032 it is.
Old Aug 9, 2008 | 08:08 PM
Car: '87 Iroc-Z
so with my current heads I can only run the 2032 without machining the heads? Could I possible reach 350hp on that combo along with my other mods till I can afford new heads and swap cam again?
LMK
ps the iroc is finally coming along after almost a year n half of having em
Old Aug 9, 2008 | 09:33 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Its kind of a hard decision. When I had the 350 in my car, all I had was some edelbrock shorties and edelbrock heads along with a zz9 cam and made 292 to the rear wheels. I think the zz9 cam had a little more lift than the 2032. I would go with the 2032
Old Aug 9, 2008 | 09:39 PM
Car: '87 Iroc-Z
Thanks I appreciate it! You dont see too many built-up 3rdgens in Missouri either, Nice To See Some other Missourian's got the passion
Old Sep 1, 2008 | 04:08 PM
Car: '87 Iroc-Z
ttt
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
